driveshaft getting stuck please diagnose
tundrabeagle3
Ca
My driveshaft gets stuck when i tighten the bolts on the side cover snuggly. It wont allow me to pull start engine do i need a washer or something for the driveshaft ?
Badot
Is the crankshaft bent?
Did you mix and match parts?
Are you sure everything is seated in as far as it goes?
Aside from that... if you don't put much info in, you aren't getting much out.
tundrabeagle3
Ca
fixed the problem already, the gasket i had was too thin so i got another one and stacked it on top and now it does not stick anymore.
