Wilson_Engine_Shop
Supporter
I finally found a long flat desolate road to test the top speed on my stage 2 Murray Explorer with a 30 series TAV and governor delete. It was revving quickly from 3,500 to 5,000 rpm then it just stopped revving and took a long time (probably another 1/8th mile) to go from 5,000 rpms to 5,100 rpms. I'm curious if i've found the limit of the stock driver pulley? I was thinking about getting the Juggernaut pulley since my motor is built to go to 7k+ rpm.
Also, after the last top speed run I noticed that my catch can had spewed blowby out of the top vent filter and the bottom drain and was all over the frame lol. Do I need to put O-rings around the fittings or get a better catch can? Its just the $25 catch can from GPS
