driven unit issues, rebuild help
*ryan
my cart sat for a while
had to rebuild the engine becuase the valve got stuck open from sitting
so i got the engine back together and running good
went to go, no movement
if its on blocks and tires arent touching, they spin
as soon as its on the ground, nothing
took the driver unit apart and lubed it up real good
still same
measured belt and it was 1/8" narrow
so i ordered a new belt
decided to take the driven unit apart to lube it up real good
well got the coil snap ring off
and thats about as far as i got
couldnt get it any further aprt
so i put the ring back on
put the belt on
started it up
drove 5' :thumbsup: and then nothing :toetap05:
looked and the coil ring was coming off, and looked like the spring came unwound some
so now i have to take it apart for real this time
only problem is it wont come apart
any tips on how to get the driven unit apart?
and how to set it back up with the spring properly?
it says its a comet, and i see a 20 stamped on it
thank you
*ryan
well got the thing apart
lots of beating, some pulling and some prying and it did come part
does the spring have to be compressed any? rotated any? befor i put it back, if so how much?
