Drive-shaft. help pls
project
hi all. I am building a small off road buggy as a school project and have a question about the drive shaft.
I want to know which material is best to use. The power is going to came from a 2 cylinder 250cc 4 stroke engine. The energy will then be transferred to a sprocket fixed on a live axil drive shaft.
My materials of choice are either: EN 24 or
Stainless 316.
Which of them you all think is best? also I want to hear of more options and why you think it will be suitable.
Thanks for your time and input.
Project
fowler
Bullsbrook West Aus
Normal 1" dia mild steel will do fine
U can buy it from a karting web site along with all your sprockets and so on
It comes with a 1/4" key way
project
thanks fowler.
My dia is going to be 1 1/4". thought mild steel doesn't have good properties for this purpose. well 10x again
fowler
Bullsbrook West Aus
It will do just fine
It wil have the tendency to flex in stead of crack
It isn't the best for a normal axle
But in this case it is the weight bearing component and 250c isn't a lot of power for this size
I agree with both of you to some extent: Stainless is just overkill, as is EN24; fowler is correct, it will have a tendency to crack rather than flex which is what you want in an axle (the flex that is). However, 1 1/4" is much stronger than 1".
So, a 1" mild steel axle should be just about perfect
project
hehe thanks all for your input.
landuse don't worry here comes an other one..
I'm still confused about the gearing.. the engine has a 14t sprocket and was thinking to mate it with a 56-60t sprocket. if that's the case I will have 1:4 ratio. is that correct? should I go higher or lower than that as the engine is 4 speed manual.
jman231994
Australia
That really depends on the first and final gear ratio's of the 4 speed, what is the particular engine...ie brand and model and all of that. We might be able to find the gear ratios
r_chez_08
Should be in the shop...
Cornwall, UK
Haha, I am even later.
I would go for 1 1/4" mild steel, because it is cheap and plenty strong enough.
Some specs on the engine and gearbox, along with tire diameters would be useful.
