Sooooo..i have a little project going on and off for the past couple of years which i hope to finish this year finally...and of course run into the big question... gearing... so need guru's help...
So far i have GX340 with inbuilt reduction gear box 2:1, witch i got for free, modified with 50lb springs, Mikuni 34mm carb/rejtted/ with air filter ,offset timing key,new style cdi, modified cooling fan,custom exhaust...port and polished head, pulls fuel pump, top plate... basically little over stage 1...next step will be bigger valves, torque cam, billet bits and governor remove...For now i have CVT Comet 30 series TAV2 1", which came standard with 10T 40/41 and 12T 35 Chain)...so the big question is what size sprockets and chain should i use to make this thing slide like ice and fly with a decent speed...My rear tires are 11x7.1x5 i do have second set of tires with PVC sleeves...
PS pictures are when i first started the project 2 years ago...
