double pulse bypass (seeking electrical component expert)
supermanotorious
Winchmaster 5000
New River, AZ
Hey guys, I would like to know how to build this module. Amazon and the like sell it for $15-$20 but I bet I could walk in to Fry's Electronic later today and buy the components I need for less than $5 if I just knew what to get.
When the module senses a 12V+ input, it outputs 12V- then nothing, then 12V- again but steady now.
Any ideas?
https://www.youtube.com/watch?v=Lb0UJQ8W3Os
Badot
Do you mean -12v or ground?
Assuming you mean ground -- in my very limited experience with electronics (so this may not be the most efficient way):
I'd run an lm339 and a 7486 with a slow cap charge for timing.
As an example, comparator 1 high cap low 8v, comparator 2 high cap low 9v, both outputs to XOR 1. Then comparator 3 high cap low 10v, the output of that and XOR 1 going to XOR 2.
That gives you a rough signal form at least. Not sure what would be required beyond that since nothing is specified.
supermanotorious
Winchmaster 5000
New River, AZ
I do mean ground rather than -12v this is to simulate a parking brake being applied, released, then applied again to bypass a head unit restriction
Ready4Dis
Look into a 555 timer. You will only need a 555 timer IC, a couple resistors and capacitors and done.
