????????????? dose someone know how many amps in to 24voltes trojan
Hippie Mike
NORTH WEST
I need to know how many amps are in a trojan battery I found out that the controller that i can use will kick off whin the battery are to low The coast of the controller is less than 80 bucks that the whole works SoIneed to know how to check the draw of amps on my battery im goiing to have to put meter to read tne amps this my wiring diagram i need to where to put amp meter can one of you fine people tell me thank you The Hippie t
Hippie Mike
NORTH WEST
Thank you for the grammar lesson Is that where the wires run in to the motor. If look at my wiring diagram have dulals motor.
mark red brown showing the runing wire to kill swich an the foot peddel. thank you hippie
ed1380
Banned
ATL, GA
set the multimeter to amps. then connect the wire of the multimeter to the battery, and the other multimeter wire to the wire that normaly should be connected to the other battery post
Hippie Mike
NORTH WEST
hot side of bettery i hook the meter
hot side of bettery i hook the meter thank you
Hippie Mike
NORTH WEST
this how i got set up
This how got my trike wires set to run my trike. Its runing reamultimeter l good so if i hook a multimeter betweethe hot side to the motor i will know how many amps the motor is useing
Kenny_McCormic
Kartless....
Michigan Troll
You will blow the meter up with that much current, most meters cant handle over 10 amps. Past 10 amps needs a clamp on(just clamps to the line and "sees" the current moving). A DC clamp (not all clampers work with DC) meter will run at least $40. http://www.bestofferbuy.com/Unit-UT...ource=gbase&utm_medium=cse&utm_campaign=gbase
When you test you should stall the motors, the reading you get at stall (only stall long enough to read)is max draw.
Hippie Mike
NORTH WEST
What if was i was to get meter that can read more than ten amp meter that mybe rado shack sale when my battery are low i need to know i can go three aere four day on full charge the controler that thinke has cut of when the batterys are low thats between 4 or 5 miles a day
DAElectric
The controller will cut off when the voltage drops below a set voltage not a set amps.
If you want to keep an eye on the amps while you are driving it I suggest that you install an AMP meter.
Search ebay for DC Shunt AMP meter. Found tons of them when I did a test search just now.
Basicaly the shunt goes where you have the meter listed post #11 of this thread.
I also suggest that you mount a voltage gauge as that will tell you how clse you are getting to the cut off point. The amp gauge just tells you how fast you are getting there.
