Since I'm too cheap to buy one...
Sometimes you want to apply compressed air to a cylinder. It can:
*Keep the piston/recip assembly from moving when you need to hold it still
*Keep the valves shut and held firmly while you install or remove the keepers and springs
*Allow you to locate compression losses
*Allow the attachment of a leak-down tester
It basically amounts to an air fitting that you screw into the spark plug hole. So- I started with an air fitting (male quick-connect) and an old J17 spark plug.
I cut the center electrode off, and chucked the plug in my vise. I then proceeded to beat the living crap out of the ceramic insulator with a hammer and punch, until all I was left with was the hollow steel component of the spark plug. PSA- Use safety glasses when you do this- ceramic is basically glass, and it would suck to have a chunk fly into your eye.
I selected a male Milton-style quick connect plug, with a male 1/4" NPT fitting on it. Please note that some are steel and some are brass. You need a steel one for this.
The threaded male portion of the quick-connect just fit into the top of the spark plug body. Nice! I put a large nut over the plug threads to protect them from weld spatter, and C-clamped the affair together. I welded the air fitting to the spark plug, and Voila! The last pic is a test run on an old 3hp Briggs. (And by doing so, I learned that the valves weren't seating worth a dang!)
). I might even find a solid block of aluminum and drill and tap it to come up with something decent looking.
