Diy old school gas tanks
anickode
S.E. Michigan
I just love the look of these little tinplate tanks, so I made another one.
Can is from a used-up liter of Pentosin CHF, with another empty pvc primer can for the neck and cap. The paint on the can was a pain to remove. I had to use acetone and steel wool.
I also unrolled the sidewall of the primer can and flattened it out to cut a rectangle to cap the end of the tank where the pour spout used to be. The adhesive label was a bit of a pain to remove, but the sidewalls of the primer can are smooth, not ribbed, so it was ideal material.
Since the top of the tank is flat, I put the neck in from the inside before capping the end to make the top a little cleaner looking.
Those are cool little tanks... Reminds me of those model steam and hit/miss engines the model engineer guys make...
Do you use a torch or hand copper??
anickode
S.E. Michigan
I've just used a torch so far. Have to be real careful with the heat or it'll burn the tin off the can. I do have a big beefy soldering iron (250 watts I think?) for leaded glass and larger electrical work. Might have to give that a try on the next go.
That's cool... I used to work in a sheetmetal factory.. Was one of the primary solder'ers of the shop... We did things old school with coppers and furnace...
None the less that's cool... Was thinking I need to get some more soldered pieces on my bikes...
