anickode
I just love the look of these little tinplate tanks, so I made another one.
Can is from a used-up liter of Pentosin CHF, with another empty pvc primer can for the neck and cap. The paint on the can was a pain to remove. I had to use acetone and steel wool.
I also unrolled the sidewall of the primer can and flattened it out to cut a rectangle to cap the end of the tank where the pour spout used to be. The adhesive label was a bit of a pain to remove, but the sidewalls of the primer can are smooth, not ribbed, so it was ideal material.
Since the top of the tank is flat, I put the neck in from the inside before capping the end to make the top a little cleaner looking.
