ok so where do i start.. I started this build back in january 2010 (i think) i decided after i got a new field car to replace my 1989 nissan sunny that it would be a shame not to do something with the engine which was pretty good and 86hp stock so plenty of power for a cart which will hopefully come in at under 500kg..
So after getting my father on board (metal fabricator ftw
) as i was just gone 16 at the time and this was going to be my first build of any kind, we stripped the engine out of the car. Unfortunately dad had already cut the wishbones, track rods and one drive shaft as he wanted the hubs for a trailer
leading to difficulties down the line...
Ok so the first step was to obviously make the frame, we searched the internet looking for a design that we liked and then we used ratio's etc to get rough demensions, then it was time to start fabricating
our state of the art CAD system
might be hard to see but we used chalk on the floor and used a centre line to get our bends/measurements right
then we started bending
floor (changed at a later stage):
the ''sidewall'':
Unfortunately at times the pictures skip a few steps as i hadn't thought as far as a build thread at the time but we then made two hoops for make and front of the ''cab'', and more tubes to join top and floor together
im just going to add all of the frame is made with 42mm mild steel tube and the main bracing done with 33mm mild steel tube.
so we got as far as this:
Progress slowed down considerably after this as i was back to school dad was busy at work and the search for suspension/steeering set-up began.
Thats all i have time for at the moment, ill update asap once i refresh my memory and sort out picture, this build is probably 90% finished and is driving at last
comments/opinions/suggestions are welcome and il do my best to answer questions..
leading to difficulties down the line...Ok so the first step was to obviously make the frame, we searched the internet looking for a design that we liked and then we used ratio's etc to get rough demensions, then it was time to start fabricating
the ''sidewall'':
