well, i don't believe i ever saw a plastic lever used, but yes the point is valid...the low-power Whizzers used a fairly weak tension-spring & required fine-tuning, and were notorious for either slip & squeal, or idle-creep. the pic shows a new (centrifugal i guess) center-pulley upgrade that apparenty solves the problem.
i've ridden older Whizzers, the lever's not that bad...but i doubt if i would consider a hand-lever with the horsepower y'all deal with, & the strong tension-springs needed.
the early bonifide motorcycles (ie big engines, purpose-built frames & wheels) would usually use a foot-pedal for slip-clutch operation...
