Disconnect oil sensor
Oil sensor wire exits the engine block through a bulkhead fitting (you'll see a nut) on the lower "front" side of the engine block. It's to the lower right of the kill switch, and under the rectangular module. Just unplug it, and tape up the wire ends.
