StreakerKart
Hey what's up guys! I was just hoping you guys could tell me how to disconnect the low oil sensor OR show me some step by step
photos or a video.
photos or a video.
Ok I do not have pics but here goes. I use the little silver box as a kill switch.
1 Disconnect the yellow wire from the plug going to the block. (the one on the block just dangles)
2 leave the other wire attached to the shut off switch
3 Now run the yellow wire (From the silver box) to the driver compartment
4 attach it to a momentary switch (like a horn button)
5 the other wire from the horn button goes to ground.
This gives you an insant OFF with the touch of a button.
Most aftermarket kart or minibike shutoffs are hold down the button till the motor grounds out. This is much better.
Good luck. post your pics and questions
Not when you attach it to the low oil cutoff box. Once it grounds, it turns the engine off, even if it loses ground a fraction of a second later.
