dirty carburator
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Okay so I'm doing a favor for a friend by fixing his mower. The mower is a B & S 30 series 148cc. It'll start up and run for 2 seconds, then it dies out. Obviously this is without question a problem with the carburator. Now when I took it off, I was expecting to see a carb similar to those on a Honda vertical shaft. To my surprise, it has the gasket as well as the valves much like a 2 stroke. My question is.. what exactly needs to be cleaned? The metal part is connected to the gas tank. I'm going to blow out all the holes with carb cleaner. Other than that, its just a plastic piece with the primer bulb and inside is a small brass hole. Looks like the hole the needle goes into in a float type carb. He also said it'll continue to run if he keeps pushing the primer bulb. Bottomline it just looks like there's not too much to clean. Any help is appreciated.
Brandon1023
needs an oil change
Okay got it. Not sure what I even had to do to make it run, honestly. The carb was clean but I still blew the holes out anyway. Aside from that, I made a new gasket and put fresh gas. Then it turned on with the first pull.
tx7750680
if it runs when you press the prim button and then dies, the jet is probally cloged
