OK, so first the heat shield needs to come off. (The aluminum covering) What you need to do is bend the pipe without creating too sharp of a angle. Ideally the angle of each cut&bend should be kept to under 45 degrees, less is better. The reason for the shallow angle is because the returning pulses/waves tend to get scattered when bouncing off high angles, reducing the effectiveness of it (less escaping air/fuel mix gets shoved back into the cylinder). It doesnt matter that the bends will be sharp angles without any smooth radius to them like your pipe, it was just made that way because it is easier to mass produce a hydro formed chamber than a hand welded one.
This is what I mean by sharp angles without a smooth radius
I don't think I can explain how the pipe needs to be bent any better in words than the picture can so just tell me if you cant make sense of it and I'll try to explain.
EDIT: Oh, the green arrows mean the pipe section rotate in that direction. The black V's are the cutouts and the black lines are where the cutouts get inserted.
