Direct drive to clutched type
alexbundgaard
Luxembourg
I’m thinking of rebuild my go-kart from direct drive to clutched type.
I can see there are all kind of clutches so hope you can help me find the right one for my project.
It is for hobby use only so let’s try keep the price down.
I have attached some photos, it is the same kart there are just some before and after photos.
My engine is a DAP T85 - 100cc - around 25-28ps and max rpm is around 18000.
Real axel is 50mm
Hope you can help me,
Since this is a racing style kart, why not a DBR manual clutch?
I'm guessing a typo... 18k rpm's, not 180k.....;)
alexbundgaard
Luxembourg
Please see photo of the output shaft.
I'm sorry, but tapered?..
I don't know if there is any clutch that will fit your crankshaft as it is now.
I'm afraid you'll have it machined or have an adapter made,
I'd suggest last, since that'd give you the chance of maybe find a cheaper clutch
and also it wouldn't weaken your actual shaft...
And as a bonus: you can move the clutch outward to take care of clearance issues with the crankcase.
But racing clutches for enignes alike are expensive anyways.. having an adapter made isn't exactly cheap either;
you sure you want to go that route?
Maybe a clutch made for the kt82 will fit, But I doubt it,
maybe you need to have one of those fancy horstmann HDC-5CX clutches;
Also please check that your shaft isn't splined or something, that would make things worse :D
firemanjim
Just kartin' around....
Houston Texas
With the precision machine shops in your area, id have an adaptor made to fit your shaft. Tapered id with a 3/4" od and drilled and tapped to thread onto your shaft.... there at the end.... ? Welcome to DIYGK
This could be the way forward....
I'm sorry.. no..
You can use the original thread of the crankshaft, since it's only 5cm long..
say you need one cm for the locking nut, another cm for the clearance to the crankcase, 5mm collar (?)...
that would leave you 2.5 - 3 cm for the actual clutch..
I don't think you'll find a clutch that slim.
Starter wheel is great for.. well starting the kart,
it's useless if you want to "stop and go" with the kart ;)
