Dingo deuce build
gman3850
gilbert az
Manco Deuce build
Was searching the old interwebs for a new project and came across this bahemous. It is a Manco Deuce. I picked it up for a little more than I wanted to pay ($200). But I have been looking for one for ages and all the ones that usually come up they want 2k for them.
So I had some tires sitting in storage so I picked up some steel rims for golf carts and bolted them on. It has a great stance. Now I have to deal the steering as the tie rod mounting tabs on the spindles that are bent to ****
kevbo22
Colorado
Ya that looks good with those tires and wheels! What size tire and wheel? Id say 2 bills for that was a pretty good deal.
gman3850
gilbert az
I've got a 420cc motor that is slightly built sitting on the shelf. Should be around 20 or so hp
Motor spects:
420cc
10:1 compression
Flat top piston
Billet rod
Nr racing 280 marine grind
1.1:1 champion rockers
Port and polished head
24mm 3 circuit carb
Big airbox (flows the same as k&n style filter)
1" open exhaust (exhaust most likely to be changed )
Adultlife
Motor spects:
420cc
10:1 compression
Flat top piston
Billet rod
24mm 3 circuit carb
That’s it?:cornut:
