Dingo clutch or Torque Converter Problem
kowalik
Hello everyone Im looking for an expert...
I purchased for my son a used Manco Dingo which the guy told me just needed a throttle cable. I replaced it and no I cant get the Kart to move. The belt looks rather loose so obvious answer is to get a new belt, but not sure if the Torque converter is the issue... Heres a link to the video of it running and maybe its obvious to someone here.
https://vimeo.com/182256412
Any help would be appreciated as my kid is pissed I bought a used toy and something is always wrong. But overall the Kart looks fine and engine starts on first pull.
Thanks in advance
Robert
Bbqjoe
Banned
Location, Location
It appears to me your driver is shot. When you increase the throttle, the back side of your driver (the front pulley) should expand and make contact with the belt.
It may or may not be self repairable. Open it up, and it may be obvious what is wrong. If not, once you have it opened up, take a pic, and let us see from there.
Joe
PS please find a better way to show pics/videos. No one wants to download somebody else's stuff.
kowalik
Thanks BBQ
appreciate the help. sorry I tried to post the video here but it wouldnt allow the format. Ill try to find another service to stream it...
Robert
Bbqjoe
Banned
Location, Location
Ok, here's what you do.
How old is the kid?
Get him to do this if he can.
1. Turn the engine off let it cool down for a half hour or so.
2. remove spark plug wire. Pull it off by the cap, not the WIRE!
3. Remove the spark plug.
4. Obtain a few feet of rope smaller than the opening where the spark plug was.
5. Feed rope into spark plug hole. If you can't get very much in, pull the starter rope a little, and more will go in, get as much as you can in there.
Using whatever kind of wrench you have, unloosen the bolt on the front pully.
6. Normally the whole assembly will slide right off. Sometimes in two pieces. It's ok don't worry if it does. If it comes off in one piece, separate the halves.
7. Take a few pictures of the guts, and post them here.
Joe
Await further instructions. (if you like)
I'll be around for a few hours.
Well this will not work reliably after being repaired either..
IDK who made that backplate.. but it MUST NOT be crooked that way.
the pulleys are NOT lined up as they need to be..
the inner sheaves (the ones closer to the engine) need to be perfectly inline,
so that the belt runs perfectly straight, or it'll wear prematurely (and since a belt costs ~25 dollars.. every few hours of driving time.. that's not too funny...)
also your driven pulley is missing some buttons..
they need to be in place,
otherwise your chances grow that you ruin the torsion spring in the driven unit (the rear one that's currently not moving on your kart)
So while your at it, fix all the issues you have, or you'll be back at it again in no time.
Remove all of the TC (belt both pulleys) and do a proper maintenance on them.
Driver:
https://www.youtube.com/watch?v=C9yPHtfJO9w
Driven:
https://www.youtube.com/watch?v=IGeFOuWmsBk
when reinstalling make sure the belt runs perfectly straight ...
To remove the driver you can use an impact wrench if you have one, if you use a piece of rope;
use nylon rope only (paracord works well) you must be sure that nothing will be left inside the cylinder.. and natural rope might end up breaking under the pressure applied.
FreeRunner15
driven pulley. Look.
try changing the driven spring to hole # 3.
---------- Post added at 10:20 PM ---------- Previous post was at 10:19 PM ----------
your belt IS crooked too by-the-way.
Bbqjoe
Banned
Location, Location
I was too busy watching the belt and drives.
Everything looks bent to snapleracket!
FreeRunner15
I've gained a lot of torque and horsepower.
When I downgraded to a weaker driven spring my belt would NOT grab correctly.
I dont know what mods you have done to the engine but you either need to get a Yellow driven spring, a new belt, or ..ahem..lose weight. A considerable amount of it.
Poboy kartman
Senior Moments Member
White Settlement Texas
Nice comment hey! Do you even know this person?
She bought the kart used, and it doesn't work.
You should burn for being such an rabbit hat!
He doesn't make anything but dumb🐴, πŸ”πŸ posts where he talks about some πŸ™ŠπŸ’©πŸ‘Ž he's done whether relevant or not....and usually not. He needs to lose some πŸ‘… because noone wants to πŸ‘‚his πŸ’© and he ought to be πŸ‘ŠtoπŸ’€.
WOW...
First since this is most important:
Robert, what ever you do.. DO NOT listen to anything FreeRunner says!
Do not trust in his advice, nothing he said above is in any way relevant to your problem.
At best he's just wrong, at worst his advice is downright dangerous.
And this holds true for nearly everything he ever said, and -sadly- likely everything he ever will say in the future.
So be warned ;)
Joe, Robert signed his first post with his name, so we can be pretty confident about him being a "he",
so yeah, well.. uhm... :D
Doug, you found your emoji keyboard? :D
Too bad these don't don't render on anything but mobile devices.. and likely not all of them correctly.
it's basically unreadable, thanks to that and missing linebreaks :(
just saying buddy, just saying ;)
Poboy kartman
WOW...
So be warned ;)
Ahhh...shucks!!! Still, gotta be more coherent than a FR post.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
WOW...
I can read all of his little pictures on my HP Pavillion g7 Laptop.
So you have a different Verdana font than everyone else.. cool..
verdana itself (the default font in this forum) does not support emojis...
OH wait.. there's a chrome plugin afaik that enables emoji support...
any chance you're on chrome ?
kowalik
OK today I pulled off the driver and realized its dirty and rusted. but then I tried to pull off the Driven clutch and see its missing spring. Which is another reason the system failed. I tried to pull her off an its not budging. Any clues of what Im doing wrong?
Logic tells me to replace the entire comet clutch system. How do i know which one it is? saw a video on youtube saying if front driver clutch has flat plate near engine its 30 series. BTW the front driver on mine is also missing the bushing.
heres photos of the back one.
it's a series 30 for sure..
considering the parts you need, I think your best bet is indeed to find a clone on ebay (~80 USD for a TAvKit)
to remove the driven pulley you will need penetrating oil (a can or two) and a lot of patience I'm afraid it's pretty gunked up...
Do not be too violent there, since you will have an easier time if you do not mushroom that jackshaft of yours.
So, you can either buy all the missing bits and pieces (mfgsupply.com has everything you need.. but you might find the one or other item cheaper elsewhere *shrugs*)
And with some additional elbowgrease it'll be as good as new and BETTER than a clone you buy on ebay or something.
On the other hand the clone is quickly bought and installed much less hassle and we haven't had any complaints so far about their functionality/reliability..
your choice.
