Dingo 8.5hp tecumseh torque converter
KoreyB
Hello new to the thread and go karting, building a track at my new house this summer and have about 9 karts coming between family and friends. Trying to make mine quick. Bought a manco dingo with a 4.5hp Briggs on it, pulled it off and I am replacing it with an 8.5hp Tecumseh cast iron engine with electric start. It has an 3/4" shaft on it and I am trying to buy the correct torque converter for it. Any ideas? Is more info on the engine needed? I have been looking at the gtc website for converters. Any feedback is much appreciated.
souperman000
Westlake Village, CA
Thats interesting, most 8 hps and up have 1 inch shafts. All the same, a comet 30 series will work for you. They really only handle up to 8 hp, but they are the only ones with a 3/4" shaft. The next level (40 series) has a 1" bore.
KoreyB
I'm guessing I will probably need a jack shaft with that as well? I'm very new to this and am trying to figure out all of the things needed to get moving.
If you get a Comet TAV2, or a GTC or equivalent, it is a complete all-in-1 unit- requiring NO seperate jackshaft or other components. It bolts directly to the engine block, and you need only run a chain to your axle.
KoreyB
I was looking at the all in 1 units, but it appears they do not make one for my size engine. I have an 8.5hp Tecumseh that has a 3/4 shaft. The 3/4 bore converter seems to be only rated to 7hp. Will this still work?
KoreyB
They sell separate converter that is not a kit, but then I would need a jack shaft kit, the only one they sell there is 5/8th so that will not work either. I hope it wont burn it up if it is only rated for 7 hp? What do you think?
Nodroz
Belgium (Europe)
Well, saying that the torque convertor is rated at 7hp and your engine produces 8.5hp, you'll burn out belts much faster than normally.
Is there no other way to get a CVT with a higher rating for a 3/4" axle?
