Differential
mike75925
thinker and tinkerer
Alto, tx
none of the diff's currently available for karts would hold up in my mind. and diff is almost strictly for asphalt karts, maybe a bit of off-roading. you get in mud, have fun picking it up and moving it over.
freakboy
the names 'mater
hick town
i wouldnt bother cause with a bike engine and a live axle you can always just peg the throtal and then spin the kart around ahaha.
r_chez_08
Should be in the shop...
Cornwall, UK
That's wat I thought I was just trying to prove some mates wrong, they were going" with no diff you can't turn" I was like no lol thanks
TurtleMann14
Insane plan member
West Virginia
well, truth be told, you can't turn as well, but yes you can still turn
if you are going to make a kart for asphalt racing then you will need a diff.
if you don't have a diff you will have additional forces making your kart want to go straight.
the wider the rear axle and the more grip your drive tires have the more force will be applied
but, it you are on a loose surface much power will be lost spinning one wheel while the other just sits there
anderkart
Surprise Arizona USA
A properly setup race kart chassis (Shifter/Sprint/whatever) is designed to transfer weight away from the inside tire while turning, this lowers the traction of the inside tire and alows the live axle kart to easly make turns without having to "spin the kart around". (so they dont need or even want any type of differential) However If someone were to of just instaled a motorcycle engine on the average fun/yard type kart, it might be a diferent story.
porsche930dude
Upstate, NY
i had a diff on my 175cc 2 stroke kart it blew up pretty quickly and i even had small skinny tires on it. It turns no problem with a solid axle. But im putting big atv tires on it now with lots more grip so i dunno how its going to behave now
modelengineer
Lord of the noise
Sydney, Australia
None of the superkarts around here use diffs, and they run 250cc bike engines will aerodynamic bodies. They're crazy!
mike75925
Alto, tx
diff is to help in steering. if you have the chance to ride a vehicle with a locking diff, do so. ride a course with it posi'ed, then with diff. with posi, you have to start turning way earlier than with diff. posi tends to keep pushing forward instead of turning. with a diff, when turning, the inside wheel gets the bind causing the outside wheel to get the power thus turning you faster.
