Diesel bobber clutch problem...
sonofwind
Istanbul
Hi.This is my new 10 hp diesel bobber.I used scooter cvt clutch for my engine but i have some problems with my clutch.When i accelerate (near top)the gas,cvt didn't engage:mad2:.What is the problem of my cvt clutch?.Have a nice day.
Nodroz
Belgium (Europe)
This CVT is VERY similar to my CVT, that's in my 2stroke moped.
As you may know, 2stroke engines rev much higher in rpm than 4stroke engines. This might be your problem...
I suspect that IS the problem. Your engine is not hitting the engagement speed of the CVT. For example- a 2-stroke snowmobile CVT that doesn't engage until 4000RPM. Therefore, a governed industrial engine at 3600RPM wouldn't even move.
Nodroz
Belgium (Europe)
:iagree:
If you replace the springs of your clutch with springs that engage at 1200rpm, you'd be fine I guess. I'm not sure if they exist though... Unfortunately, you may need to look for a whole new CVT.
exenos
Project Nut
It looks like you have two drive units from a cvt. The drive should be open when idling/off and the driven should be closed all the way, it looks like it's open.
Nodroz
Belgium (Europe)
With this type of CVT, the driven spins too when the engine is idling. Inside the driven there is a centrifugal clutch, that transfers the engine power to his jackshaft.
Altough, the driven should be fully open (right pulley). Are you sure you're at the right distance between your driver and driven? (and the right belt)
sonofwind
Istanbul
:iagree:
This is the turning point.I know that i have to replace the springs of my clutch with springs that engage at 1000-1200rpm.And i am going to replace springs of my clutch and i will use my clutch without springs then i start my engine and we willl see what will happen.Thanks for your comment.
sonofwind
Istanbul
I removed three springs from my clutch.I started my engine without springs and accelerated gas but nothing is changed.:mad:
beansdaddy78
JR. Member
Carbondale IL.
does the clutch need the springs to engage??? im asking because i dont know and hope someone will answer.
did you find the springs that engage at a lower rpm??? if so id like to get some too
newrider3
Colorado
How is that driver mounted on the crankshaft? Looks like it's hanging off the very end, or even just bolted on...this is going to put very excessive sideloading on your engine's crank and bearings.
sonofwind
Istanbul
As you know i have a clutch problem with my bike.I thought that i could use 125 cc motorcycle gear box.But my engine is nominal 3000rpm,max 3600 rpm and motorcycle engine is 7000/8000rpm.Does this rpm difference make any problem?Photos:
carter
Well I'm pretty sure that the 7-8 k is its rated handling. But the reductions might be a tad slow if you are at half the RPM's. I don't know what the reductions are but they might be a tad high for your purposes.
Nodroz
Belgium (Europe)
You could solve that by getting a smaller diameter sprocket on the engine an a slightly larger on the gearbox. Or would this cause problems?
