Deuce wont start
1happydude
Bristol, CT
Hi All,
So I finally got a chance to work on my deuce. 12hp tecumseh.
The electric start works and cranks the engine but no start.
I changed the oil, flushed the gas tank with new fuel and got a new spark plug. I used a spark plug light tester and it flashes when I crank. The fuel line seems to be getting gas to the carb as well. The air filter is serviceable.
I cranked it about 50times and got a few signs of life but no real luck.
Any suggestions?
2SlickNick
American Minibikes @ FB
Mesa, AZ.
True. Might as well order a valve cover gasket to that way you can see if valves need adjusted too.
1happydude
Bristol, CT
I got her running! I spent my whole off day re running a new kill switch, cleaned the carb and adjusted the choke.
Its not the cleanest sounding engine, but it moves the kart steadily. I spent the rest of my day mounting a 32inch led light bar.
