- Messages
- 2,788
- Reaction score
- 3,736
What you did to install the belt is normal. Also you can put the belt on the clutches, off of the kart, and then grab one with each hand and slide them onto the crank and jack shaft at the same time. Works well for me. In post # 18, picture
# 3 of the spring and weight you might have that on backwards. I can't be sure from the picture. The weights are angled on both sides. But one side is much steeper than the other. That has to go on facing inwards towards the engine, as that is the surface that pushes the driver closed as rpm builds. Also make sure the clover leafed slider has the end with the boss that is milled off straight on two sides is pointing away from the engine. The outer bell of the clutch mates up to it.
