The TC in our Yerf-Dog 3200 (repowered with a HF Predator 212cc) is OK, but I must say that I am not thrilled with it.
Right up front, let me say that I have read the torque converter sticky and that the advice provided seems spot on.
I have a feeling that we might be a good candidate for deep-sixing the TC and replacing it with a centrifugal clutch.
All of our riding is on asphalt, with modest hills and a few sharp turns, including two U turns that are tight and must be negotiated slowly.
I feel that a properly-chosen centrifugal clutch would simplify things and provide adequate performance.
We are not after top speed with this cart as, IMHO, although we have taken steps to improve the handling and plan to make some more changes in that regard, this will never be a race kart. 30 mph is fine, anything more than that would be gravy but I see no need for it to top 40 under any circumstances.
I understand that I have to select the right clutch based on the wet weight of the kart, gear ratios, tire diameter and so on. I have not gotten to that yet.
My first question is if you pros agree that this might be a good thing to do, and also to enquire about cent clutches that kick in and lock up at specific (low) rpm. I have had good luck with these in the past on a smaller, lighter cart. Would they be a good choice for my Yerf? (My intention would be to minimize some of the seemingly inescapable low-speed slip.)
I'd recommend a Comet setup if you want ease of maintenance. They've
