decypher Honda engines
B_Bimmer
Can anyone who really knows their Honda's give me some good solid basics. There is really not much out there and I can't find a shop manual or good parts diagrams with serial number changes and part numbers anywhere on the internet.
So, some background. I got a good deal on some gx240's with 6 to 1 gear reduction. Obviously most things don't need gear reduction so I was wondering if I could just switch the side cover and crank and tada, have a more useful engine. This is what started me on my quest for knowledge but what I want to know is not limited to that.
My requests start with the very basic question. If I buy their shop manual will it have parts diagrams and numbers? This would allow me to cross reference and figure out what is needed and if it's worth it quite simply, but if they aren't in there I really don't need a $30 book to tell me what I already know. I could take them to pieces and get them back together running without a book.
Second is there a guide to what all the crazy numbers and letters mean in the seemingly endless variations they make? That would seem really helpful, and I sure can't find one.
Third, has anyone tried to lose the gear reduction? If so, what did you need? After all, that's all I really need to know, I just would like to know far more.
Too bad the 6:1 gear reduction doesn't come with a wet clutch...
otherwise it'd be the perfect engine for a go kart... (running 1:1 to the axle and you'll be set most of the times)
Anyways
The correct answer to your intitial question will be:
PERHAPS!
Sorry, but there are at least two different shop manuals out there for the GX series (covering the GX240)
One covers every little detail on the engine except the part numbers (only tool part numbers are mentioned), and the other one is less detailed but comes with part numbers...
(IIRC one's green and the other one's red.. but can't tell which one's what tbh but I think the green is the detailed-no part numbers one)
I THINK one is more a shop manual (ordering parts, telling the client what'll be needed) and the other one a repair manual (for the actual guy in coveralls)
but
the crank case number is 11300-ZE2-600 (99.8% certain for the complete set with bearings and governor)
the crank (straight shaft 1" [there's also a slightly shorter 25mm straight shaft]) should be 13320-ZE2-600 (for engine serial number up to 1494214)
and 13320-ZE2-600 (for serial numbers starting from 1494215)
(well above 95% certainty)
Why such odd certainties?
Well the parts numbers changed over the years.. so the age (and serial number) of the engine matters to find the exact part numbers as well.
I used:
http://www.honda-engines-eu.com/web/eec-public-site/shop-manuals
to find the parts numbers picking GX240 QE as the engine in question...
second:
Yes there is a reference for the numbers.. it's in the "other manual" (the one that comes with numbers - IIRC called parts manual indeed)
Other than that not much.. whats the difference between an Q-type or R type (or s, v etc...) yes that's easy to find out..
what's the difference between parts with a declaration of ZE2 vs the ZE3 parts.. not that I know of (not outside the parts manual)
I think you could do some research online to find out... but I can't tell.
third: for sure, but not me.. so....yeah :D
B_Bimmer
Updates, since there is not much out there on this and I think it could possibly be useful to someone. The parts manual is called a "Parts Catalog" by honda, of course using the correct terms will get you a lot more results on ebay and the like. The service manual is called a "Shop Manual". Honda apparently does a very good job of keeping all of the above in digital format locked up on the internet, since none of my normal methods found me anything. I sure like subaru for that, anything you could want available on their website. Anyway, the site itsid linked is as good as anything, Thank you for that.
Shaft differences all seem to make okay sense, all my engines are Type HA2. The model code on the two better ones is GCAKK, and one the one for parts with a thrown rod GC04. None of these seem to directly pull up parts with my serial numbers on any sites, they all claim not a valid number. I am still trying to figure out if mine are GX240UT1 or GX240UT2. Any thoughts or clarification is welcome.
From most of what I can find it looks like virtually every part is the same internally except for the obvious crank, side cover, and gear reduction stuff, and there are is an aftermarket seller on a site named after a rain forest that sells a crank and side cover for GX240's without feeling the need to say select serials or anything, so I'm tempted to give that a shot and see how it goes. Any opinions of aftermarket parts of this nature?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Opinion
There are so many Chinese Clones of these engines, Especially the 200. I would safely assume that the "no serial" number parts on AMAZON (I'll say it) will probably be fine. Typically we can mix and match Honda parts with Clone parts.
Typically... However the Predator series from HF is not a true Clone and only some parts fit. (I know you never mentioned Predator)
If I were you and "tempted" I would give it a shot. ESpecially since the seller is using the trademarked "GX240" it will most likely not be an issue. Best of luck.
