dcastillo
Thought I'd make a thread just for my build im thinking of starting. Havent been to active on here lately, just so much going on with 3 kids...
Attached is my current Kart, bought it used and modified it for electric... It works fine, uses a 2Kw 30yr old golf cart motor and 6 batteries. Surprisingly I can ride it with all three kids, very tight squeeze. But it wont last much longer without money, rear axle is a hack job, rims are welded to it... once the treads gone, its going to be 150-200 to redo the rear end, not worth it to me
My plan is:
-main driving is 70% pavement, 20% light trail/grass/dirt, 10% medium trail (ditches, mounds, roots, etc)
-something about 12" longer, and 6-10" wider then current cart
-I want a single seat in the front and two seats in the back
-to keep size down, back seats may need to be mounted over tires (putting them about 18" off ground (dont think its a huge issue since performance isnt key here and the batteries will be low and forward on the cart)
- Batteries mounted next to driver
-electronics between rear passengers
-solid axle with ~16" tires (similar to what I have now)
-front tires around 12-14" with manco style springed spindles
-steel frame with square tubing for easy welding
-disc brake
-etek motor (need around 4-6Kw, this thing will be heavy)
-reuse my current 200A kelly controller and 250A E-Stop
-will definitely need to add reverse on this beast
sadly, due to finances and time, this build may take 6months, but thats OK.
Just wanted to run this by some of the more experienced builders for feedback. Does my plan seem reasonable? Has anyone built a three seater like this?
I plan on starting the concept drawings in the next few weeks and will post them.
thanx
Danny
My plan is:
-disc brake
thanx
Danny
