Daikon Raider 150 - Engine Swap
badabing86
So I have all my parts for the engine swap of a 420cc into the go kart.
My only issues is the live axle sprocket I ordered was a 1" bore but did not fit. It was too small of a bore. Does anyone know what bore to order or suggest a specific one to use for this application
Most sprockets bolt to a hub, not directly to the axle. If the bolt pattern of the sprocket matches the hub, you could have the inner diameter of the sprocket machined out to the proper size. Or just keep shopping for another sprocket. Get a set of calipers and take an accurate measurement before ordering.
