Dag Nabbit!!!
Bbqjoe
Banned
Location, Location
It appears I'm having a real problem with this minuki carb. The engine keeps locking up when off, and then trying to start it again.
I changed fuel so it isn't water in the gas, it's gas leaking into the cylinder and crankcase.
I'm going to take the bowl off tomorrow and check the float and needle for debris or whatever. I'll also change the oil twice once I find the problem. I haven't seen any fuel coming out of the overflow though.
Any other suggestions guys? This carb is being a real challenge.
Staff Murderator
Yep. Did you remove the plug and crank the gas out of the cylinder?
I've got a 17 HP Briggs lawn tractor engine doing the same thing between cutting. Instead of fixing the carb, I fixed in an inline fuel shutoff valve. Then I flip the switch and run it dry for the shutoff process. :)
Bbqjoe
Banned
Location, Location
Installing a petcock will be the last resort. AFAIC, this shouldn't be happening with a new carb.
