CVT trouble
fowler
Bullsbrook West Aus
for our primary bike on the farm we have a 2004 Kawasaki 360 workhorse with just over 11k on the clock
t has done that on a single belt and a single set of tyres that are more strings than oem rubber
it has run like a beast for a long time
pulled stuff 3 times its own weight, rolled 6 times, crashed into trees and bogged well into the chassis more times than i can count it is used when bigger vehicals cant be and gets treated pretty rough
recently it was sent back to the dealer to fix a few issues and when it came back it had more issues :censored:
they have replaced the driver clutch and a small solenoid on the clutch housing as it wasn't disengaging
they tryed to fix the front brakes that kept locking up
after driving it for a few hours today the brake locked:censored:
because they had over filled the reservoir, lucky they were locked as the bolts holding the pads in were half out and i was able to catch it
iv never played with the cvt clutches so wouldn't know how to diagnose one
it has a small soliniod on the side which seems to operate a small lockup clutch somewhere in the driver but im not sure about that
when u press the throttle it starts to move as it should till it reaches the point of lock up and it makes a noise similar to spur cut gears and that turns to a wine at higher speeds
then every now and again it will just lock up half way though the rev range and the bike will just take off hell for leather or light up the rear tyres but the niose still persists
it is definitly in the driver and not in the solinoid although the soliniod isnt working right either
the whole cvt is enclosed in a sealed case that takes air from the air box
is there any go to points or common cvt issues that may cause or that i can fix with ease
if not then it is going back to the dealer but that wont be for a week or more and we really need the bike to get places the vehicals cant
dout it matters but the bike has 3 gears, low, high and reverse and it has 4 wheel drive by switch
