CVT info need
truitt
joplin MO
CVT info needed
I have a 2006 carter 150cc and I want to put a 250cc-300cc motor on it. I know I need a CVT or something automatic but I don't know enough about CVTs to know what engines I can or can't use with a CVT and what CVT I want(clutch, TQ, gearing, ect).
the engine you're talking about is very likely a gy6 engine..
thus it comes with it's CVT installed already.
You cannot reuse that one obviously, but you can get the 300cc gy6 that too comes with an inbuild cvt and you'd be done.
You can also just buy any motorcycle/scooter engine in your desired size to fit it in..
some come with a 4spd gearbox, others with a cvt.
Make sure to keep the F'n'R gearbox (on the very end of the drive train) if you have one, it'll likely fit the 300cc gy6 derivate just nicely and you don't need to buy a new one ;)
If you want to pick an industrial engine, then you'll lose power..
(the 420cc is as powerfull as your 150cc just slower!)
and your cvt of choice would be a Comet series 40 Torque converter.
truitt
joplin MO
thanks. ive been looking for used 250cc and 300cc gy6 engines for ever and can't find any. I've found new ones but they're like $1000.
what models of used gy6 engines should I look for? cause typing in 250cc gy6 doesn't pop anything up
well IIRC the bigger than 150cc are not a gy6... gy6 only is kindof the keyword for scooter engines with cvts...
here's a used 250cc honda:
http://www.ebay.com/itm/HONDA-85-86...OMPLETE-ENGINE-MOTOR-TRANS-6170-/261738508101
here's another:
http://www.ebay.com/itm/99-Honda-CN250-CN-250-Helix-Scooter-engine-motor-/272241213366
here's a chinese one:
http://www.ebay.com/itm/Shanghai-Jmstar-Scooter-JSD250-Engine-Motor-88530-/351741957423
just search for "scooter engine" and add 250 or 300 as you like to see what's popping up.
