cv hald shafts?
fowler
Bullsbrook West Aus
i thought i should collect some more parts off the mitzi colt in the dump so i went to collect the front hubs and cv half shafts
To cut a long story short i messed with rusty bolts for half an hour and got to remove the cv. Someone told me u would just slide them outta the gear box but when i tryed i got only half of the gearbox joint :mad2: which probs isnmt sopose to happan
So how do i get the other peice of the joint out :worried2:
Cam
Nz Petrolhead
Whangarei, New Zealand
on the japs you can wedge a screw driver between the housing and internal cv, or a crowbar, they have retaining rings on the shafts inside the housing, and will pop out sooner or later, you might have to remove a cover to get the crowbar/driver in as seen on the toyotas i have worked on but im not sure as i dont usually play with mitsi's.
fowler
Bullsbrook West Aus
i cant realy remove a cover as that cover has the engiune mount bolted to it
ill try the old more force till somthing gives way
as im sure u can image a car in a dump it is sitting on its belly and hard to access areas.
i might take the tractor down there and flip the car over
if these cvs wont slide in and out of the box then were is the give when the suspension moves up and down?
PS
does it change anything if i say im removing the short side?
Rustydog2010
NZ Nutta :|
New Zealand
Just take the whole car home? lol
The give is either in the splines like this or the CV joint can slide within its housing like this..
Usually, on the ones I have done, when you take the outer out of the hub the inner just slides out?
Jeremy.
fowler
Bullsbrook West Aus
we already have too much stuff in the sheds that should be in the dump
i decided not to flip it i just lifted it and put a truck tyre under it but i did still manage to modify the roof
i got both front hubs and i left the long cv in place and the gearbox bit of the short cv isnt going to come out without me removeing the cover and thereby pulling the engine out
i think ill just buy two short cvs from the wreakers or use keyed uni joints and get a stub shaft made up
the front hubs look so useful as they have 3 arms from which i can mount a arms or trailing arms, so on and so on
