Custom clutch cover
ironman
I'm Back!
kentucky
Looking for some custom ideas for clutch cover to bolt on to predator motor
strainers can be quite interesting IYAM...
if you happen to find one in a good diameter with a flat bottom (like an insert from a pasta pot)
that'd be great..
mesh also works if it's stiff enough.
Or a cheap camping pot (aluminium) with a set of drilled holes for cooling and looks..
You can also use about any plastic container that's somewhat appealing and has the right size...
I work in a HVAC sheetmetal factory. On my bosses mini bike, he made a Clutch cover with a 4" or 5" spun plug, for spiral pipe. It looks like a flat bottom dish of sorts but its the right size for the clutch... He also joined a bit of metal onto it to make a chain guard.....
A coffee can,Hub caps of certain vehicles, ect can also be used...
