bbrewer2005
- Messages
- 34
- Reaction score
- 0
So I've got a ct200uex. Its got a predator 212 with a stage 1 kit, and a torque converter. I have the factory 50t rear sprocket and a 9t jackshaft sprocket on the converter for a 5.4x ratio.
In it's current configuration with my 220lb self, it will do 49-52 mph depending on wind and distance at wot. I've got it to 52mph once. It will typically do 48-50 with a long stretch of straight road depending on ambient temps. This is all tested with a GPS.
I just bought a 60t rear sprocket, and a vm22 mikuni carb. I'm also going to remove the governer. Any ideas on what my theoretical top speed should be with those two mods?
Think I should be able to do 55mph? I also have a 10t jackshaft gear I can use to play around with ratios.
