Crossfire conundrum
90droptop
HOUSTON TEXAS
I do, I'm going to load it up Saturday and test it. It's the same size case, but has a different out put, I can swap that out if needed.
90droptop
HOUSTON TEXAS
Second engine had no compression either. I'm going to tear down the first one and see how bad the jug looks, if it is okay I may just buy a piston and ring kit.
If it's not I'm going to look at a big bore kit.
90droptop
HOUSTON TEXAS
Finally have a Saturday off work tomorrow. I'm going to bring both gy6's up to work and tear them down, see what they need and start ordering parts. May just do a rebuild on the quad motor and a performance build on the cart motor
90droptop
HOUSTON TEXAS
Tore both engines down, found cylinder and Piston in one to be crapped out. The other has a good cylinder, good piston, good rings and a bad head. So I took the good parts off of one and put them in the motor that bolts into the crossfire. Now I have compression and new oil. Also swapped the good clutch and belt from one to the other. Essentially I have a good shape gy6 ready to bolt in just got to get a new ignition coil and plug.
J_Walker
Florida
the honda rebel motorcycle engines can be had for pretty cheap... check craigslist, but I've always found those things in motorcycle scarp yards. most can be had for 50 bucks. just know what you're looking for when picking them out at the scarp yards.
its got everything but reverse.. 16 HP. and a transmission.
DaveP
Daddy Gearhead BusDriver!
Lake Odessa, Michigan
What out put shaft does it have,, or how to you get the power to the axle gear??
90droptop
HOUSTON TEXAS
Okay so let's pretend I have no working knowledge of the gy6 electronic system.
Some one walk me through wiring it up please
gman3850
gilbert az
is your wiring ac or dc 4/2 wires or 3/1 wire set up coming from cdi. as for wiring harness here is an ac wiring harness i made/ used other diagrams and made one that fit my need
90droptop
HOUSTON TEXAS
4/2 ac, I am not to concerned with lights at the moment I just want to ensure that I have the engine portion of the harness wired properly. The cart had a hack job ratsnest of twist caps and scotch locks. I ordered a new performance cdi box, ignition coil, spark pkug, and air filter, they should be here this weekend. Hope I can get it fired up on the bench before installing it in the cart.
90droptop
HOUSTON TEXAS
Success! !!!!!!!!!!!!!!!
Cart motor 1 has fuel, air, and fire. She runs on brake clean, now to mock up a fuel cell for the crossfire, to see if it will run down the street
J_Walker
Florida
darn never realized I was asked a question.. :oops:
You would go based off the stock sprocket size. I believe 520x108 chain is what goes on the rebels. [don't quote me on that] you would just need to find a rear sprocket that would fit your drive shaft that also fits 520 chains Or have a hub built/machined to fit/bolt stock sprockets onto.
Also congrats on the movement OP! :useless:
90droptop
HOUSTON TEXAS
Just placed an order for a new rear caliper, brake pads, a fuel tank and a muffler. And while I wait on those parts I'm will be installing my seats, harnesses, and separate electrical system for the lights, I plan on running a couple led light bars.
90droptop
HOUSTON TEXAS
Video will be posted soon on the movement my wife has a root canal and has been a big baby about it, also her dog just had major surgery on its leg so she freaking out about that.
