crankshaft help
nissinator
kansas
i was replacing my clutch an when i put the screw into the crankshaft to hold the clutch on i cross threaded it:oops: anyway to get it out an restart?
r_chez_08
Should be in the shop...
Cornwall, UK
Put some clean nylon rope down the spark plug hole, untill it fills the cylinder. Use appropriate spanner or socket to remove. You may also want to run a tap through it to fix up the threads
