Cranking with key off
Skuzzlebutt
Just bought a 2008 Fox Carbide 150. Has a dead battery so I used the jump pack to start. Runs fine with the pack on but once it's disconnected it will die... sometimes. Other times it stays running after it's jumped and pack is disconnected and to further confuse me, now it will crank once I hook up the jump pack even with the key off. I even unplugged the ignition switch harness and it cranks once the jump pack is turned on. Any advice?
Skuzzlebutt
I just brought it home today so I haven't had a chance yet to get a new battery. That doesn't explain why it would crank with the key off.
I realize that. There must be some wires crossed or connected improperly somewhere. But you made it sound like after the initial start up it was doing OK.
I have seen a fresh battery clean up electrical gremlins. You need one any, so that's why I suggested it.
