Coverting a generator engine to a go cart
Cam
Nz Petrolhead
Whangarei, New Zealand
Awesome man, ingenuity right there.... i have a friends crankshaft, out of a gx 340/360? generator motor im going to attempt to stick in the lathe
Bluethunder3320
nice. i see a wire coming out of the oil plug, is that the low oil shutoff? take it out because it will only run when the engine is stationary...
That's not necessarily true. The low oil circuit is still intact on my GX340. I thrash the wee out of it off road, and it has only hiccuped on the hardest jolts. Still, you can safely unplug it. Just be a good boy and keep an eye on the oil level.
And- Jeez, that's a long shaft!
redsox985
PA
Did you have it filled properly. Straight out of the box usually isn't filled correctly.
mrspicer
Pics?
Also a generator engine is likely to have a tapered shaft which you need to convert to Q shaft to easily use it on a kart.
This is true. But. If you knock the rotor off the rotor shaft then have the shaft machined to 4 1/2" long 3/4 diam with a key-way slot. Use a 5' shaft bolt to secure the new shaft to the crank shaft. Using a clutch that will withstand 14hp and a 4" sprocket that cart will fly.
jmjbot
i have the same issue and im brand new to engines. if someone could come to my post and help me it would be great. thanks
jmjbot
If there's enough material there to have it machined to 3/4", do so. You will find plenty of clutches in that size. Worry about that first. The throttle's gravy.
can you find my thread and help me with the throttle part because the shaft part is not an issue for me.
joshkidner
West Michigan
on mine i took the tank of the top and loosened the bolt on the top that keeps the throttle adjustment tight, then modded the throttle pedal with a spring and hooked it up ;) but to me it looks like yours doesnt have the lever that protrudes out and says high-low (theres a rectangle cut out) which is where mine is hooked. do you have that piece? if not look it up online and try to find it everything else is the same and it should just bolt in
