Cam
Nz Petrolhead
Awesome man, ingenuity right there.... i have a friends crankshaft, out of a gx 340/360? generator motor im going to attempt to stick in the lathe
low oil shutoff? take it out because it will only run when the engine is stationary...
And- Jeez, that's a long shaft!
Pics?
Also a generator engine is likely to have a tapered shaft which you need to convert to Q shaft to easily use it on a kart.
can you find my thread and help me with the throttle part because the shaft part is not an issue for me.If there's enough material there to have it machined to 3/4", do so. You will find plenty of clutches in that size. Worry about that first. The throttle's gravy.
