I've been working on the Streaker. I have a thread going on the other page but I have a couple questions or ideas I need confirmation on.
Both pedals had a lot of wear and slop. When I pulled them off the kart I discovered the bolts were welded to the pedals. Was this how these things came from the builder or was it owner add on?
I'm sure I can grind them off and weld in replacement but what a pain.
Next question. The steering rod got bent. Can I just cut it off and weld in a piece from Lowe's to replace the bent stuff? I was thinking about joining it up with a piece of tubing and weld it in there. Seems like a good idea to me, what would you guys suggest?
Spindles. They look like big bolts welded on to a small piece of pipe with a short section of flat bar stock welded on to that. True? Or not? Seems like I could make my own replacement?
It's been a long hot day. I've been working on the back porch. Time for a nap!
