Cooling a snowmobile engine...
sno-kart
Where can I find a civic radiator with smaller fittings? That's our biggest concern with that one. If we can't what does a reducer look like for radiator hoses? Thanks...
fowler
Bullsbrook West Aus
A reducer is just two bits of pipe welded together
Each of its own size
U would have to search though eBay to find a reduced outlet rad
Search EG EK manual radiator
FatCat
2 stroke Addict!
Ottawa, IL
Sorry if I'm writing the same as someone else. Didn't read the whole thread. Honda civic radiator with an electric fan. No chance the stock radiator will keep it cool. Lots if guys use civic radiator in buggy swaps and the work great. You shouldn't have any issues with that setup. Alright just read through it. Fowlers pointing you in the right direction. I run the fan through a switch on my buggy. Once its warmed up I turn the fan on and leave it on even a few minutes after I shut it off. No need to turn it off while moving. Save you $40 on a thermo switch. Don't worry about an oil cooler though. That 2 stroke doesn't have oil to cool. No offense to the tuner guy but don't spray cool water on the engine. Bad idea especially on the exhaust. A civic radiator is the hot ticket for sled engines during summer time.
sno-kart
Awesome, thanks. The consensus certainly seems to be that a 2 row civic radiator with a 12" fan would be ideal. They are inexpensive and I'm sure would get the job done based on what I'm reading. The one issue with a civic radiator is it's size. They are roughly 14.25"L x 17"H x 2"W and that would be hard to fit onto our kart without it looking a bit ridiculous (see model below for an idea). So, after doing some more research, I came across mini cooper radiators that are being sold on ebay. They are aluminum, 2 row radiators, same as the civic ones, but are smaller (about 10.5"L x 14"H x 2"W). This would fit and look a lot better, but of course the downside is less surface area. The last thing we want is to get a radiator and have it not be enough to cool the motor and have to buy another one...
I want to see if I'm thinking about this correctly, so here are some specs of the original vs. civic vs. cooper radiators:
Original Kawasaki Rad
Core size: 10.5" x 6" x 2" (I believe it's 2 row, just based on measuring the width at 2"... see pictures)
Surface area: 126 in.sq.
Fan: None
Additional cooling: snow cooled heat exchanger
2 Row Civic Rad
Core size: 14.25" x 13.75" x 1.50"
Surface area: 294 in.sq.
Fan: 12" puller
http://www.ebay.com/itm/2-ROW-ALUMI...Parts_Accessories&hash=item27c133f0a9&vxp=mtr
2 Row Mini Cooper Rad
Core size: 10.375""x 10.25"x 1.75"
Surface area: 186 in.sq.
Fan: 10" puller
http://www.ebay.com/itm/250853937681?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Does this mean the cooper radiator will be only slightly better than the stock unit and the civic radiator's cooling capacity will be over double the stock unit?
Below is a 3D model of what the cooper radiator (left) would look like vs. the civic radiator (right).
Should we even consider the cooper radiator with a 10" fan based on this? Assuming these are all made of aluminum, are the surface area or the radiator and the # or rows the only significant factors to consider? Thank you!
Since I know nothing about the sled- There's no fan? Well no wonder it'll overheat at idle. Has anybody considered the notion that an electric fan shrouded to the stock rad would grossly outperform the non-fanned original?
That said, you could get away with the Mini rad, I'm sure. Be sure to use a shroud to maximise thermal transfer efficiency. The factory Mini shroud combined with a factory fan and rad are a no-brainer match.
If you were not planning on running a fan, then you need a big@ss rad. If it were up to me, I'd use a smaller rad and fan.
EDIT- Another thought- Have you considered dual rads? A couple of bike rads (with fans), one on each side. If they can keep a high-performance bike engine comfy in a summer traffic jam, I can't imagine why they couldn't keep a sled engine cool.
sno-kart
That's a good point. The snowmobile did not have a fan for the radiator... however it did have a heat exchanger at the rear of the tunnel which was cooled by snow being kicked up by the tread. So the coolant ran from the water pump, to the radiator, then to the snow cooled heat exchanger, and then back to the motor. It certainly makes sense that the engine overheats at idle since there is no air moving through the rad and no snow being kicked up onto the heat exchanger.
However, my buddy who owns the same model Kawi snowmobile that we got our engine out of said that this engine generates a lot of heat, and even when the snowmobile is at speed, but there is no loose snow to throw onto the heat exchanger, it will run hot. Since we obviously won't have the heat exchanger, I feel that based on his experience, the stock radiator would definitely not be enough, even with a fan. Again, we just don't want to buy the Cooper rad and have it not be enough. That's why I'm trying to do the math to see if I can get some certainty that the Cooper radiator will be enough before purchasing it.
I understand what you're saying, but I counter with this:
The stock sled rad (without fan) relies on air being forced through it at speed. I would imagine that the rad is NOT out in the open, but behind some bodywork- with vent openings, I'm sure. Now- Can you imagine the heat transfer efficiency if you were to duct a high-performance fan to it? I guarantee it would stay cool. Armed with that concept, I would bet a paycheck that the Mini rad, shroud, and fan will do the job just fine.
fowler
Bullsbrook West Aus
Ha forgot we are working with two strokes
Yeah that wouldn't work too well
U proberbly could use a copper rad
But then cost comes into it
If its cheap enough to go that option then u can
Dual rads may work if u are keen to have double the lines running
But bike rads are usually long, skint and curved
They dot really fit in a situation when u want the rad as high as possible in a wide area
sno-kart
That doesn't sound encouraging lol. An aluminum 2 row radiator won't cut it? I was just thinking that the mini cooper radiator is made for a car with a low revving four stroke that puts out no more than 50hp probably. I need to cool a 70hp two stroke so not sure if that would be enough. Do you guys think the civic radiator won't cut it either? Thanks for all the help.
sno-kart
Ahh ok. What do you think about the fact that the cooper radiator is designed to cool a small four stroke putting out no more than 50-60hp while I'm trying to cool a 70+hp two stroke which revs to 8k rpm? I was about to click buy on a cooper radiator on ebay but then thought about this... what are your guys' thoughts? Again, we just don't want to spend north of $100 on a radiator/fan and then have it not be enough. Thanks
Ted Hamilton
Vintage Kart Afficionado
King, NC
Be aware that moving air too quickly through a rad will not give it time to heat up and remove heat energy from the coolant.... a thicker core rad with slower airflow may be better....ducting on the face would be a good idea.... Good luck!
fowler
Bullsbrook West Aus
A mister isn't a good idea
A mister is a short term thing to get out of an emergency
I agree with ted
A good thick rad is good
And volume over speed
sno-kart
Thank you all very much for the input. After reading everyone's suggestions, I think we'll be getting a 50mm Mini Cooper radiator...
http://www.ebay.com/itm/290789048356?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
...they are a bit more pricey than the 40mm ones but will offer better cooling and slower airflow. This, paired with a 10" fan, should hopefully do the trick. I don't know how effective misting would be, but I'm not sure I like the idea of spraying the spark plugs and exhaust with water. Also, it seems to be fairly costly anyway.
