coolest or oddest motors
TurtleMann14
Insane plan member
West Virginia
its some where in the rx8 hand book... its supposed to prolong the seal life and make sure it all cools down at the same speed
anderkart
Surprise Arizona USA
Back in the 1970's/80's before Honda offered the GX-series overhead valve engines they made the G-series flathheads in serveral sizes. They offered the G35, G42/50, G65/80, G100, G150, G200, G300 and the largest was the G400 like mine pictured below:
Its a 406cc./24.8 cid. - 10hp model with 16.6 ft. lbs of torque. They weighed 72lbs and were avalible with or w/o electric start.
Here's my G400 sitting next to a GX390:
________________________________
My other oddball engine is a Tecumseh Star. This engine was highly modified version of their H100/10hp industrial model and intended to be used for kart racing. They were sold in an un-assembled kit form complete with a 3-stage header and a Tillotson HL363 Methanol carb. Its specs were 357cc./21.82cid. with a 3.312" bore and 2.532 stroke. These engines produced around 20hp (had no govenor/reved to 7000rpm) with the stock parts but had the potental of reaching somewhere near 40hp when further modified and up to 50hp when ran on a Methanol/Nitro mix.
These engines bolt right up to a standard Briggs-5hp/Honda GX200/6.5-clone motor mount but are wider and come with a larger 1" pto sizing. They made/sold about 1000 of these before the componey bit the dust a few years ago.
Kenny_McCormic
Kartless....
Michigan Troll
You have to let them warm up and warm down for 10 mins or so.
Man do I have some engines to add to this thread, will tomorrow when I get some pics :devil2: .
Hayden
All engines are supposed to be warmed up or run easy till they get hot. As for cooling down, that's usually a turbo related thing, buy a turbo timer and you are good to go.
mike75925
thinker and tinkerer
Alto, tx
my dad has had 3 xj650 turbos. in the avatar next to my name, is the scroll from a 650's turbo.
Fast Eddie
Out in the garage
Kinda odd, but becoming a little mainstream on here. Vertical shaft lawnmower engines turned horizontal. My twin Lawn Boy Duraforce engines currently going together for a Rupp Dart I'm building.
robin
in a house
its a 750 motor i have a turbo kicking about it could thro on it but i think it will go bang it had 40000 miles on it lol
KieranM
Doin It!!
Kilkenny, Ireland
anyone know much about the hydrogen engines. i have seen a few vids of 2hp engines running on it, but its apparently very temperamental. I think that bmw have brought out a car with a hydrogen engine? anyone know much about them
freakboy
the names 'mater
hick town
All i know is if you crash it you go boom.
kazkepox
Pro- one idea to the next
Panama City, Florida
ok so I have been doing alot of research on the wankel/rotary engines lately, so I will shed some light upon the subject.
The rotary was mostly known for it being used in the rx7's
http://en.wikipedia.org/wiki/Mazda_RX-7
they work alot like 2 stroke motors meaning they require 2 stroke oil.
they have 2 different sets of spark plugs, a leading and a trailing.
Their source of power is their ability to rev at very high rpms, so it doesnt fell like there is any torque untill you start getting close to a regular redline.
They are cool.
instead of pistons they use rotores (see the video)
hmm...they get bad gas mileage, its a performance motor.
kazkepox
actually most of them do. its a matter if they have an oil pump or not. the oil pump is electric and usually fails alot, so they cut corners by just premixing.
