Swabbster
- Messages
- 439
- Reaction score
- 0
these plans are for a regular type mini bike
http://www.sfu.ca/~jst4/plans/docs/bikes/Wren Mini Bike Plans.pdf
Great job! Everything seems to be going smoothly so far, but I do have one question. Why exactly did you use 3/8" plate for the motor mount!?![]()
I think he made a mistake saying 3/8. I just calculated that in cm's, and it is just over 9cm's. That is REALLY thick.
Landuse, don't buy chinese calculators.3/8" is not over 9cm. It is about 9.5 mm.
i put the pipe in my vice and bent it yes it kinked on the top bends i filled it in with weld but i will be making small gussits to weld in like small triagles in all the cornersthats good and all. but since the bends they describe in plans are not possible with the bender they tell you to use. 2" conduit bender isnt even available for one thing. you end up with kinks for bends like on your bike. and since kinks are not strong at all your better off cutting and welding the angles. other than that looks great![]()
