Good evening,
I had a question about a controller setup. I'm looking at buying a 2KW motor from Amazon that comes with a controller. Here is the diagram for the controller. I just had a couple questions to make sure I understand what goes where. I did see a post from May 2021 that was similar to this, and I did learn a few things from it.
Battery and Motor Phase- Self Explanatory
E-lock- essentially the on/off switch
Reverse- another 2 position switch
My main questions are:
1) Do I need a Hall sensor if I am using a foot pedal?
2) What is the 3 speed functionality? Does it limit max speed or does it act as a simple throttle?
3) What is the brake functionality? I planned on using a brake pedal that is attached to mechanical brakes.
4)Brake lights/indicator lights- does the controller automatically step down voltage? Or will they be the same voltage as my battery?
Here is the link to the motor and controller.
www.vevor.com
Thank you!
VEVOR 1800W Electric DC Motor Kit - 48V 4500rpm Brushless Motor with 33A High Speed Controller and Throttle Grip Kit for Go Karts E-Bike Electric Throttle Motorcycle Scooter DIY Part | VEVOR US
VEVOR Electric Motor Kit 1800W brushless motor with 4500rpm speed, sturdy aluminum construction, and included speed controller for go-karts, e-bikes, and more.
Thank you!
