Compression or carb issue?
Arkynsky
I have a hard time starting the engine, I managed to get it to fire one pop but stoped right after. I previously cleaned the carb jets but still doesn't pull a strong mist of fuel out when I crank it. I'm hoping its not my compression as it fired one pop right? The engine hasn't been started in 2 years as well. Any ideas?
Dallas, TX
The way I would test this is to get some starting fluid and then try to see if it runs better with the fluid.
If it has not been ran for two years I have a suspicion there is some major gunk in the carb. The carb may need a good soaking after two years.
As what was said on your previous thread.. you have a fuel pump.. It might not be hooked up properly To pump the fuel in the carb...
Keep to the one thread..
