comet TAV2 30 in snow?
PredatorPowaaa!!
Mistake Maker
Ontario,Canada
so, as some of you may know, canada just got a dumping of snow :censored: (1/2 a foot and still piling up):furious2: and i was wondering if it is safe to use my torque converter in snow. it is fully exposed and i don't have the plastic cover on. (it would get snow sprayed at it constantly) is it good for it?
Well, eastern Canada did... Comming back from a walk... Seemed kinda nice..
Then again overthere they tend to think of themselves as the center of the country/universe.....
I don't think it would hurt performance. It gets warm so buildup shouldn't be a problem. Don't snowmobiles use a similar setup?
Only thing I see is clean and dry afterwards to prevent rust. Maybe a relube.
well wet sheaves are not exactly helping it grip either...
So if you can you should install that cover to at least try to keep it as clean and dry as possible.
clean is the more important part here..
small stones, sticks, even leaves will not be nice to the belt, sheaves and worse internals of the TC.
So you need to take care at least.. a slightly wet TC is not too much of a problem, as long as you dry it up back home again to prevent it from collecting rust.
B_Bimmer
The tc on my old john deere snowmobile says comet industries on the side. It has always worked well with an embarrassing lack of maintenance.
Staff Murderator
Yes, but is it exposed to the elements?
Seems it's a fad to run chain and belt drives without their respective housings installed creating a potentially hazardous situation with loose arms and legs, straps, belts, fringes, etc. coming into close contact with high speed moving parts. I see this on motorcycles, mini bikes and go karts.
At one time some of the TAVs had a cooling fan attached to one of the pulleys--of course this would only be at its most effective with the housing/shroud installed.
Staff Murderator
I just saw a useful bit of info from this post: http://www.diygokarts.com/vb/showpost.php?p=444640&postcount=1
The OP posted a Comet Industries data sheet which states:
"Never allow lubricants or water to get on the belt. Oil or water can cause excessive slippage and premature wear."
That would seem to put closure on the whole matter... unless you're one of those free-spirited, careless chaps who never reads the instructions. :D
while this is perfectly good advise...
one is barely able to keep the TC belt bone dry at all times..
starting rain.... one puddle and the belt will be wet!
I'm fairly certain that a slightly wet belt, will basically dry itself (rubbing the water off on the sheaves) in a matter of a few full rotations...
and that additional wear will be barely noticeable in the long run because of such mishap.
slip... yeah well, I'm sure you'll notice that, at which point you can back off the throttle to reduce the wear even further ;)
Anyways.. that's why I said "as dry as possible"
but I still think that cleanlines is more important.
So "reinstall cover" it is anyways IMHO ;)
B_Bimmer
While not technically exposed, snow gets EVERYWHERE on a snowmobile, it's the nature of powder, and part of what makes it worth freezing for. After a decent ride the whole engine compartment is a steaming wet, slushy mess.
As to covers, they are cute, but they are always getting in the way of routine maintenance.
