Couple of questions. I tried searching. Okay running that predator 420. Have a 54 and 9 tooth sprockets with a comet 40 setup. On my driven, it's a reverse wound. But how much preload should I put on this? When lining up the driver and driven, do I want it dead even at idle? Or line it up even for wot? When it's dead even at stop or idle it lines up straight. But obviously at wot the belt runs at a angle. Am I going to get uneven wear like that? Here's some pics of the driven. Does everything look right? And how much preload would you put on this? I had to order a new driven, old one was toast. Am I going to run into problems using a 420 chain, 54 and 9 tooth sprocket combo? Thanks
