Comet 40 Series Driven Completely Seized
Thrahl
I just posted a thread yesterday about a problem with my drive clutch and got good responses that helped a lot.
But now I realized I have another problem.
My Comet 40 series driven clutch is totally locked up.
It won't spread apart at all. I guess it has been like this since I got it, I just never knew it was not working right.
It has a lot of rust on it and I'm assuming the shaft it is supposed slide on is rusted over. The spring seems to not be the issue as I can move it with just my fingers.
I have tried soaking everything in PB Blaster and putting a wooden wedge between the faces and hitting it with a hammer and it doesn't budge. It just bends the faces out.
I don't really know what to do from here.
Is there any way to take it apart completely so I can bust all of the rust off of it?
redsox985
PA
Try to take it off of the jackshaft, remove the cam, then the spring, and you should then have just the 2 faces to work with.
Thrahl
I actually just got the cam and spring off with a whole lot of elbow grease. The two faces are all that remain and they are very, very stuck.
I am soaking it periodically in PB Blaster and attempting to hammer it out and it hasn't budged so far.
I might have to pull out the torch before too long if it doesn't break.
Sorry- My bad. It's been quite some time since I disassembled mine- I forgot how they come apart. Soak it in a vat of WD-40 for a few days.
Thrahl
how old is that 40 series?
I don't know exactly. When I bought it the kart had been sitting in a few inches of water for a while out in the open.
I would imagine it is probably 5 years old or so. I really don't know though.
redsox985
PA
Soak it in some penetrating oil and maybe try 2 pullers in a few days?
