Suffolk JK
I just finished installing a 7HP Briggs into my Manco Red Fox, which has a Comet 30 clutch and 6" 30 series driven pulley. My buddy has an 8HP Briggs in his Manco Dingo with a Comet 40 clutch with a 7 1/2" driven pulley.
We were playing around yesterday since I was excited to see if I was going to be able to keep up since A) my cart is lighter and B) I'm 50 lbs. lighter than my friend...he blows my doors off at top speed and off the line by LOTS and LOTS of car lengths.
I've got half the size of tire on the rear and was very confused as to why it can't even keep up. Does it have to do with his Comet 40 and 7 1/2" driven pulley? Our axle and jackshaft sprocket are identical. I don't think 1HP would make THAT much of a difference.
My engine is running good. Carb is tuned to run perfect, it doesn't hesitate, new plug, has a return spring for the choke since it goes to half choke after a couple minutes of running. Throttle linkage does go 100% WOT. We even placed the governor spring a little on the loose side since it wasn't even revving to 3600 with the spring in the factory location. That made it feel 50 times better.
A little confused.
Thanks.
A little confused.
Thanks.
