Bosch
with the purchase of my new predator engine, I was thinking about replacing the entire torque converter as well. But I have decided to give it a chance at repairs first. I have ordered new buttons (it threw all of them off in one week).
But The main problem is that the driven pully does not articulate like it should. I have removed the cover, put the go kart up on blocks, and run it, & I have observed that the driven pulley does not "change gears", it does not articulate. The belt is more or less stuck in the middle position of the pully, regardless of rpms. This seems like a relatively simple device, so I'm not sure what to do about it, other than disassemble it and clean it. Do these things eventually go bad? Suggestions?
I recorded a simple 10 second vid of this, but haven't uploaded it yet. I'll do thaat after work this evening.
If you are still unsure Im pretty sure reading the comments below the vid (on Youtube) will put you at ease...
